automatic transmission question
Old Sep 24, 2006 | 02:23 PM
kstroeher's Avatar
kstroeher
Default automatic transmission question
I working through all the issues with my truck, basically paying the price for letting it sit for for the past year. Most everything is back the way it should be except the apparently bad plenum gasket and a shifting issue.
When cold, it is very reluctant to shift from 1st to 2nd and 2nd to third. Just takes a couple of shifts to have in working normally, but it's definately not right. I have changed out the transmission fluid (it's due again) but have never changed the filter. Will a simple tranny service with a filter change bring it back? Or is my shifting problem indicative of bigger issues?
The truck is a 2001 off-road with the 5.9, it has 62,500 miles on it. Any advise is appreciated.
Old Sep 24, 2006 | 06:04 PM
The Burning Rom's Avatar
The Burning Rom
Default RE: automatic transmission question
You can try a fluid change, filter change (you should always change the filter WITH the fluid), and adjust the transmission bands.
It could be a sign of a bigger issue though as well. It's hard to say for sure.
Old Sep 25, 2006 | 04:13 PM
kstroeher's Avatar
kstroeher
anyone else?
Old Sep 25, 2006 | 05:09 PM
Terran's Avatar
Terran
I'm taking mine to AAMCO for the "Power Purge Plus Package" to get teh fluid filter and bands done as i was having trouble with slight engine overun so you can try taht.
Edit: You're supposed to do a fuel, filter, and bands every 20K so maybe that's your problem.
