Eletric Fan Install... no pics...
Old Sep 25, 2006 | 12:45 PM
DPR250R's Avatar
DPR250R
Default Eletric Fan Install... no pics...
Whats up guys... since I found this site I have been adding a lot of mods to my truck...
I have no posted any writeups or anything because most of it has been done already... except this...
I decided to go with a 18" used Ford cooling fan. I got off of E-bay for $65 shipped...
Then decided to make things easy and use this to control it....
http://www.spalusa.com
http://cgi.ebay.com/ebaymotors/SPAL-...spagenameZWDVW
It was $75 shipped and made things real easy...
Total cost of my fan was around $130. It has worked great so far but it is getting cool outside around here. The real test will be in the hot summer.
Old Sep 25, 2006 | 01:20 PM
radwebster's Avatar
radwebster
Default RE: Eletric Fan Install... no pics...
good luck man.. i am also doing a fan install today. i will post pics when done. i have 2 19" fans i got at a swap meet the other day. paid $20 for both!
Old Sep 25, 2006 | 01:42 PM
radwebster's Avatar
radwebster
here's what i'll be working with...
they are 19" each, doubt i'll fit them both but i will damn well try! for $20 for the pair couldnt go wrong though
[IMG]local://upfiles/28056/B5200E48B4154711AB5640C9E70BE57F.jpg[/IMG]
Old Sep 25, 2006 | 01:49 PM
muddy_blue_dodge's Avatar
muddy_blue_dodge
thats a really interesting piece, that electric fan controller...... how was the install?
Old Sep 25, 2006 | 02:15 PM
junkman306's Avatar
junkman306
Did you notice a horsepower difference?
Old Sep 25, 2006 | 02:30 PM
DPR250R's Avatar
DPR250R
ORIGINAL: muddy_blue_dodge
The wiring is very easy with this controller. If you only want to run one temp sensor you have to tap off of the OEM sensor. That was the only part that took a little time (as far as wiring the controller goes). I pulled the upper hose and upper alt bracket to gain access to the wire. Tapped off of it and ran it to the controller. My controller is mounted on top of my underhood fuse box.
You can run two temp sensors... but that defeats the purpose of the controller.
Old Sep 25, 2006 | 02:31 PM
DPR250R's Avatar
DPR250R
ORIGINAL: junkman306
A little... nothing crazy.
I have done a bunch of stuff to my truck and I don't feel much difference... only in the upper RPM range which I barely use anyway.
Old Sep 25, 2006 | 02:34 PM
DPR250R's Avatar
DPR250R
ORIGINAL: radwebster
Cool man... good luck!!
That was the one nice thing about the fan I bought... it fit perfect underneath my stock shroud. I lucked out with that one cause I did not measure anything before ordering...
Old Sep 25, 2006 | 02:36 PM
junkman306's Avatar
junkman306
I see. I figured it would be worth 10-20 horsepower getting rid of that windmill.
Old Sep 25, 2006 | 02:41 PM
DPR250R's Avatar
DPR250R
Well don't get me wrong... I would def do it again!! I just had high expectations that were not met.
I was really going for more low end and a MPG increase. I have yet to run through a tank of gas so I do not know if it helped the MPG.
