A/C blows hot when brake is applied
Old Sep 25, 2006 | 09:51 PM
acurry's Avatar
acurry
Default A/C blows hot when brake is applied
Hello..I have a '99 ram with the 5.9L. The A/C works fine most of the time, but sometimes during braking, it begins to blow hot air. I then have to turn it off for a few seconds, then turn it back on to get it to blow cold again. Any suggestions would be greatly appreciated!
Old Sep 25, 2006 | 10:19 PM
heymccall's Avatar
heymccall
Default RE: A/C blows hot when brake is applied
Definitely a vacuum leak somewhere. Look for a broken plastic hose under the hood between the engine and the firewall. It'll be real small in diameter.
Old Sep 25, 2006 | 10:36 PM
shott8283's Avatar
shott8283
yea.. sounds liek a vacume leak .. your vacume isnt strong enough to hold the blender door in place.. happend to me.. if your truck is a 4X4 then check the hard lines that run from your tcase to your CAD on your front axle.. they are two small hard lines that look like brake lines.. thats where my leak was..
you could do a vacume test and see what your vacume is.. should be 18 inchs of vacume at idle
Old Sep 29, 2006 | 12:18 PM
acurry's Avatar
acurry
Thanks for the replies. I'll check the lines and keep you posted.
Old Sep 29, 2006 | 01:03 PM
spiral72's Avatar
spiral72
Hey, while your poking around in vacuum lines..... Look and see where the green hard line goes near your distributor... please?
