ATF+4 or DexronIII
Old Sep 27, 2006 | 04:34 AM
robert97dodge's Avatar
robert97dodge
Default ATF+4 or DexronIII
I have a '01 dodge ram 1500 4wd and I am putting a new tranny in the truck this week. I have always heard that you are supposed to use dexronIII on chrysler vehicles. Well this other guy I was talking to today said that he was told to use ATF+4. This other guy I know said that Wayne over at APS precision says to use ATF+4 and another guy I know says that he talked to a guy named Dave Goerend who also builds trannys and he says to use DexronIII. So which is it that I am supposed to use? I have always used NAPA brand dexronIII. NAPA is the only I have been able to buy it buy the case so that is where I always go.
Old Sep 27, 2006 | 04:48 AM
dodgerules86's Avatar
dodgerules86
Default RE: ATF+4 or DexronIII
ATF+4, and ATF+4 only. Do not use ATF+3. Do not use Dexron.
Valvoline has ATF+4 out which is priced pretty good.
Note: you can use Amsoil or Mobil 1 synthetic transmission fluids. These are either ATF+4 approved or recommended by the manufacturers for Chryslers transmissions. As far as other transmission fluids, make sure the fluid is either: ATF+4 approved, or recommened by the manufacturer for Chrysler transmissions.
Again, do not use ATF+3 or Dexron.
Old Sep 27, 2006 | 05:00 AM
robert97dodge
ORIGINAL: dodgerules86
A friend of mine is a Amsoil dealer so you think it would just be best to get a case of amsoil ATF+4 from him?? Also what about the t-case? I know in the owners manual it just says to use ATF.
Old Sep 27, 2006 | 05:12 AM
97 3.5 Intrepid's Avatar
97 3.5 Intrepid
ORIGINAL: robert97dodge
NO! NO! NO! NO! NO! NO! NO! NO! NO! NEVER EVER, EVER, EVER, EVER USE DEXRONIII! READ THE MANUAL. ATF+4 ONLY! DEXRON is an outdated crappy tranny fuild that doesn't live up to the standards of Chrysler automatics, it is like using acid in your tranny.
About the Amsoil ATF+4, I don't know. I stick with the Mopar name brand just to be safe.
Old Sep 27, 2006 | 05:30 AM
dodgerules86
There are people in this forum that have been using Amsoil in their transmissions trouble-free. (A note: Amsoil does not make an ATF+4 per-say, but a universal fluid that is compatable with ATF+4)
Yes, the transfer case takes ATF+4 as well.
You will need:
4 quarts for just a transmission filter change and fluid fill. For a flush, you will need: 10 quarts for the 42RE, 44RE, and 46RE transmissions. The 47RE transmission will take 17 quarts. (Note: these numbers are not exact, order/buy a few extra quarts)
Transfer case: NV231HD takes about 1.5 quarts. NV241 takes about 2.5 quarts. NV241HD takes about 3 quarts.
Its recommened to change your transmission and transfer case fluid around 35,000 miles (or before )
Old Sep 27, 2006 | 07:47 AM
turkeyhunter1962's Avatar
turkeyhunter1962
My local NAPA store carries the Valvoline ATF+4 and I have purchased mine there. WHen I first got my truck I could only get it from the dealership, but NAPA now carries it and the price is not too unreasonable ( at least it is better than the dealership) As everybody says DO NOT USE DEXRONIII.
Old Sep 27, 2006 | 07:58 AM
dodgerules86
I haven't checked my local NAPA, but my AutoZone has Valvoline ATF+4 for around $3.70/qt. Advance Auto Parts has it for $4.70/qt. My local WalMart sells Mopar ATF+4 for $4.50/qt. Yea, my local Wal*Mart sells the OEM stuff for a decent price.
Old Sep 27, 2006 | 12:23 PM
Tommygunz's Avatar
Tommygunz
I run Amsoil ATF and I love it, all of my fluids (fuel exempt, obviously) are Amsoil. I grew up having my grandfather as a dealer, never used anything else and I swear by it. We even used it in our tractors, antique and new.
dodgedlr's Avatar
dodgedlr
The official answer is that according to DCX everything should be "retro-filled" with ATF+4 = even your K-cars when doing a flush job.
But if the dipstick called for DexronIII you can still use DexronIII of course - even though DCX suggests to update to the ATF4.
But if it originally called for ATF4 = you MUST use ATF4
Old Sep 27, 2006 | 01:20 PM
steve05ram360's Avatar
steve05ram360
I stumbled into an incorrect labling thing at walmart... they had the $ on the Mopar ATF+4 at $3.40/qt... bought a case of 12.
