Starting/Idiling Issue
Old Sep 28, 2006 | 02:45 AM
Ryanshreds's Avatar
Ryanshreds
Default Starting/Idiling Issue
When I start my truck up (Cold) It Idles very rough. Sometimes in the winter it wont start at all unless I keep my foot on the gas and hold it until it warms up. It does fine when its warm. What should I do to fix this problem?
Thanks
Old Sep 28, 2006 | 03:15 AM
The Burning Rom's Avatar
The Burning Rom
Default RE: Starting/Idiling Issue
Check your fuel pressure
Check/clean/replace your idle air controller/valve. It's on the throttle body.
Check/replace your coolant temperature sensor. It's what helps regulate idle when the engine is cold.
