differential fluid change
Old Sep 28, 2006 | 05:52 PM
kstroeher's Avatar
kstroeher
Default differential fluid change
How often? How important is it?
Old Sep 28, 2006 | 06:02 PM
DPR250R's Avatar
DPR250R
Default RE: differential fluid change
IMO..
Anything under 15,000 is a waste...
Anything over 50,000 is pushing it...
Old Sep 28, 2006 | 06:13 PM
The Burning Rom's Avatar
The Burning Rom
Between 25,000 and 30,000 miles if you don't do a lot of towing.
Between 15,000 and 20,000 if you do a lot of towing.
It's fairly important, as having your rear-end rebuilt can run you between $500 and $1000.
BTW, it's also VERY important to change the fluid by removing the differential cover. That way you can make sure the bottom of the housing clean and gunk free, and can also check for metal shavings/loose metal/gear wear.
