brake problem
Old Oct 4, 2006 | 10:53 PM
DieselDemon's Avatar
DieselDemon
Default RE: brake problem
Glad to hear someone else understands the sequence of bleeding a 95. Someone mentioned gravity bleeding before. It works to a certain extent. I can personally attest to the fact that that combo valve is a poorly designed setup. I think it's the tolerances. They could have been much tighter, more precision. Same with their master cylinders. If any time you had to slam the pedal to the floor, you would roll an O-ring back and forth in the manifolds. It wore down the actual tolerances. Fluid leaks by.
I hope ya get it figured out Jasper. Buy a hydroboost unit, have to hydraulic hoses made, and problem solved.
Good luck.
