U joint troubles
Old Oct 2, 2006 | 12:32 AM
hanra's Avatar
hanra
Default U joint troubles
Hello new here and looking for some help. I have a 2001 Ram 4x4. I have been trying to grease the front U-joints and am not having any luck. I bought the needle I was told to use and when I insert it into the joint I either bend it or completely break it off. Any ideas as to what I am doing wrong or is there an easier way to go about this task? Any help what so ever would be greatly appriciated.
Old Oct 2, 2006 | 12:35 AM
timwag2001's Avatar
timwag2001
Default RE: U joint troubles
are they the stock u-joints? when i replaced mine the new ones had grease fittings
Old Oct 2, 2006 | 12:42 AM
kstroeher's Avatar
kstroeher
My 2001 stock ones were sealed.
Old Oct 2, 2006 | 03:44 AM
hanra's Avatar
hanra
hello again. No they aren't stock I just had them replaced and they told me to grease them. There is a hole into wich I am supposed to insert this needle. Every time I try I either bend the needle or break it off. Just looking for some advice as to how to grease these.
Old Oct 2, 2006 | 03:53 AM
silverram99's Avatar
silverram99
Sounds like the hole you are talking about should have a grease fitting in it. I have never heard of using a needle and whatever crooked shop installed u-joints without grease fittings should be put out of business.
Old Oct 2, 2006 | 09:37 AM
timwag2001's Avatar
timwag2001
do they look like regular grease fittings?
Old Oct 2, 2006 | 11:14 AM
2001ramsport's Avatar
2001ramsport
some have a small threaded plug that you can remove and screw in a grease fitting.thats how mine are
Old Oct 2, 2006 | 12:43 PM
Socha_62's Avatar
Socha_62
Yeah, sounds to me like your missing the zerk that screws into the hole. Its a small peice that threads right in and you stick the needle into that. I'd call the shop and ask them what they did with it.
Old Oct 2, 2006 | 07:05 PM
hanra's Avatar
hanra
Thanks for the info. Now the hole i was referring to is on the endcap of the joint. If i put a fitting there it won't hit anything important will it?
Old Oct 2, 2006 | 07:10 PM
silverram99
Ok from what you are describing it sounds like you might have got some of those AutoZone U-joints that are sealed. I think you should go back to the shop that installed them and demand that they install u joints that are greaseable. The hole for the grease fitting on most u joints is in the body of the joint itself so I doubt the location you are talking about is the correct one.
