fuel injectors
Old Oct 2, 2006 | 01:27 AM
timwag2001's Avatar
timwag2001
Default fuel injectors
im pulling my intake off this week and was thinking aobut replacing the injectors. My engine is pretty much stock. how many lbs can i go up to with out it being too much?
Old Oct 2, 2006 | 02:18 AM
Silver_Dodge's Avatar
Silver_Dodge
Default RE: fuel injectors
Anything over stock will be too much unless you plan to have your PCM flashed to go with the new injectors. The stock PCM setting just won't know what to do with larger injectors, and you will likely run rich. Also, the stock injectors are good for over 600hp (I know of several built Dakotas that are still running stock injectors). So unless you have seriously built you engine, going bigger on injectors is not necessary. If your engine is stock or near stock, you have a lot of work to do first before you will ever actually need larger injectors.
Old Oct 2, 2006 | 02:23 AM
timwag2001's Avatar
timwag2001
thanks for the info.
