Was lookin for a set of clearance lights. want to put some on my 97 1500 4x4. Does someone sell them? Or will i end up havin to go to the junkyard or something, would rather buy new ones. thxs for any info
Ebay.
OR
Buy 5 from an online supplier. Wire them up yourself. Pull the headliner, drill some holes, rig it up to a toggle and fuse or put it in your stock fuse block or stock running lights.
Oh yeh, I'd rather be stroked then rammed!
OR
k, thxs
theres many quotes out there, all opinions. but you should get to a ford forum if your gonna talk bout dodge on a dodge forum...JMO
but yup, thxs anyways.
funny how dodge is the only true diesel today huh...
I would go directly to your Dodge dealer and order their kit, I added cab lights few months ago and thought I'd be different and order a clear set from RECON, I'll never do that again, after they reassured me twice the kit came with everything I needed, when it showed up there was only the lights and gaskets, and wouldn't return my calls. Called the dodge dealer to try and get mounting screws and such, only way to get them was to order the complete kit for around $80 I believe. From what I was told the kit from Dodge includes everything (someone correct me if I'm wrong) but inlcudes lights, gaskets, mounting screws, template and wiring harness.
Found a really good looking set at Styling Concepts.
http://www.stylinconcepts.com/parts....tfamilyid/1551
Guess this is the set the other forum member did not like. Glad for his input.
[IMG]local://upfiles/35230/DAFA8AE4C1294DBAB27A28E6120C34D6.jpg[/IMG]
Quote:
ORIGINAL: Maintain
Ebay.
OR
I'd be happy to hook a chain to your truck and give you the lesson of your life. I embarass Ford drivers on a daily basis. ORIGINAL: Maintain
Ebay.
OR
Powerstrokes are for beginners. Come back when you have something road worthy.
Forgot to metion earlier, I do like the way the clear lenses look, especially on my white pickup, was just almost more of a hassle than I wanted to deal with to get them on there. The make pickups look so much better at night too, esp on the Ram
i got a 97 White 1500 4x4 that i want to put them on. The truck has the factory lift. I did put 285's on it which makes it look alot tougher. Wasnt to sure about puttin clearance lights on it, but i think it would look really sweet. thxs for the input.
