Front rotors
Old Oct 6, 2006 | 12:11 PM
ratlird's Avatar
ratlird
Default Front rotors
I'm getting ready to replace the front pads on my 01 Ram 1500 QC 2 WD and since I have 89,000 miles on it and they brakes are pulsating I figure I would replace the rotors at the same time. My question is what is involved in doing this.
Old Oct 6, 2006 | 12:24 PM
silverram99's Avatar
silverram99
Default RE: Front rotors
Really not much at all. You will need a 3/8 allen head socket to remove the caliper with. I can't remember if your wheel bearings are sealed or not, they aren't on my 99, if yours aren't then now is a good time to inspect/re-pack them with grease. It is a really straight forward job, once you get the caliper off the rotors come off easily. Good Luck and Welcome to the Forum.
Old Oct 6, 2006 | 01:00 PM
Racinfan83's Avatar
Racinfan83
Yep, remove the caliper and the rotors come right off. I got a set of cheap ones for $30 ea at NAPA. Easier to replace than to take and get them turned. Make sure your caliper bolts are tight when you put it back together. I had an issue after I did mine, one of the bolts came loose and fell out. Trust me - you don't want this to happen! Use some Lock-Tite or something on the threads and get them tight.
Old Oct 6, 2006 | 01:06 PM
ratlird's Avatar
ratlird
Thanks Silverram99 and Racinfan83 for the info. I wasn't sure if you had to pull the wheel bearings on the newer models like you use to have to do.
