plenum removal
Old Oct 6, 2006 | 11:47 PM
timwag2001's Avatar
timwag2001
Default plenum removal
i know this is in another post but i wanted to make sure you see my question.
when i took off the intake though some debris fell into the valley i put some rags in there when i took it off but the initial removal is where it happened. i vacuumed it out and cleaned it with some rags but im nervous about leaving stuff in there. also... when i was scraping the gaskets i think some stuff went into the heads. i vacuumed it out like the manual says. Is this ok? should i just run it a little and then change the oil? what do you think?
Old Oct 7, 2006 | 02:14 AM
steve05ram360's Avatar
steve05ram360
Default RE: plenum removal
you should be fine. as long as it's not metal scrapings... gasket material will get blown out from the cylinders and as long as you picked up as much as you can out of the valley you'll be ok... next time put a rag down there.
Old Oct 7, 2006 | 02:19 AM
timwag2001's Avatar
timwag2001
the gasket material fell in when i initially pulled the manifold off. i put rags in once i got it off though.
Old Oct 7, 2006 | 02:46 AM
silverram99's Avatar
silverram99
Yeah you shouldn't have any problems, just like Steve said anything soft will go through the cylinders without any problems. It is the hard stuff like metal and aluminum pieces that will cause your motor to fail. Nothing you can really do about that first initial bit of stuff that falls in anyway.
Old Oct 7, 2006 | 02:50 AM
timwag2001's Avatar
timwag2001
do you think an oil change after a few miles is a good idea?
Old Oct 7, 2006 | 02:55 AM
silverram99
Not a bad idea at all, I was sure I put that in my last post but I guess not. I usually run it like 30 minutes and then change it. I just like to know that all that crap is flushed out.
Old Oct 7, 2006 | 03:02 AM
Ramdamit98's Avatar
Ramdamit98
ORIGINAL: timwag2001
It couldn't hurt. If your concerned about it all it's better to change it and be worry free. I didn't bother when I did mine, but I didn't get anything noticable in the engine. I dropped a little right on top that I was able to vacuum up.
EDIT: I was also only about 700 miles away from doing an oil change so I'm now about to do one.
Old Oct 7, 2006 | 05:03 AM
steve05ram360
if you do decide to do an oil swap, add a little MMO to it... 16 oz or so. it'll help clean up the insides real good.
Old Oct 7, 2006 | 02:49 PM
4x4_guy's Avatar
4x4_guy
i get to do this real soon.
my intake pan gasket is blown.
-Jesse-
Old Oct 7, 2006 | 03:21 PM
timwag2001's Avatar
timwag2001
its really not that hard. just a little time consuming. make sure you have a fuel line disconnect tool, torque wrench, gasket remover and something to scrape the gaskets (i used a new wood chissel, it worked great and didnt scratch) and rtv sealent. let me know if you have any questions.
