Intake Gasket Question
Old Oct 8, 2006 | 03:01 PM
05SilverHemi's Avatar
05SilverHemi
Default Intake Gasket Question
I am going to swap intakes on my truck in a the next week or 2. The fel-pro kit comes with a cork front and rear gasket. I want a rubber gasket. Any idea who makes the rubber front and rear as part of the intake set?
Old Oct 8, 2006 | 10:17 PM
1RewdRam's Avatar
1RewdRam
Default RE: Intake Gasket Question
Um ......... I just bought the Felpro intake gasket kit for my 5.2 in order to do the plenum fix and it had the rubber front and rear ...... seems odd you got cork.
Old Oct 8, 2006 | 10:39 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
My Felpro kit had the cork for the front and rear for my 1997. []
Old Oct 8, 2006 | 10:47 PM
05SilverHemi
ORIGINAL: 1RewdRam
Can I have the p/n for the intake kit.
Old Oct 8, 2006 | 11:04 PM
1RewdRam's Avatar
1RewdRam
It's down at my Uncles garage, I'll try to post it tomorrow early pm.
Old Oct 8, 2006 | 11:09 PM
timwag2001's Avatar
timwag2001
i just bought the hughes plenum kit and an intake gasket kit with the bolts. the gasket kit is for 1998-2003 318/360 magnum. it came with the rubber front and back. it was 44.95 and the part number is HUG 3205B. Im not sure if youcan order just the front and back but the part numbers might be HUG3215 and hug7700. but ill check on it.
Old Oct 8, 2006 | 11:12 PM
timwag2001's Avatar
timwag2001
i was wrong. its all included in 3205b at
http://www.hughesengines.com/partDet...p?partID=11584
Old Oct 9, 2006 | 12:05 AM
05SilverHemi
What I find interesting is it looks like the 94-97 gasket kit comes with the cork gaskets and the 98-01 comes with the rubber. Any idea why?
Old Oct 9, 2006 | 12:17 PM
Socha_62's Avatar
Socha_62
Yeah, my 97 was cork. Used RTV in the corners like your suppose to and I haven't had any problems.
Old Oct 9, 2006 | 05:37 PM
silverram99's Avatar
silverram99
For what its worth I never use those end gaskets anyway, I have never had the intake manifold off of my truck so I don't know if they are crucial or not. I usually just a lay a big bead of RTV where the gaskets would go. Most of the engines I have rebuilt are older small block Chevy's and Fords though.
