ac/heater
Old Oct 11, 2006 | 07:36 PM
engine's Avatar
engine
Default ac/heater
large amount of vapor comming out when ac or heater , defrost is on ..any ideas?
Old Oct 11, 2006 | 07:41 PM
DieselDemon's Avatar
DieselDemon
Default RE: ac/heater
Hearter core has a pinhole leak, or the drain for the condensate is plugged.
Check your coolant level and watch closely to see if you are losing anitfreeze. Then check the drain thru the firewall and make sure it's clear.
Good luck.
