Little patch of rust
Old Oct 14, 2006 | 01:52 AM
ripto's Avatar
ripto
Default Little patch of rust
Is there anything I could do to stop an area of rust from getting bigger? I just noticed it the other day but by the looks of it it must have been like that since I bought it. Its already flaking and a piece has chipped off. I don't think there would be anything I could do as a spot fix, but what do you guys think? Sorry, I don't have a pic at the moment of it but heres the area, its at like the very bottom of the passenger door, but above the thin stripe of metal that goes along the buttom of the whole truck.
[IMG]local://upfiles/21486/A63E7BF2F7C1411E8674AC5001C7D884.jpg[/IMG]
Old Oct 14, 2006 | 07:50 AM
habeba86's Avatar
habeba86
Default RE: Little patch of rust
Ya door rust on the ram is common. I agree there isnt much you can do, it is probably rusted through and on the inside part of the door you cant see....
Old Oct 14, 2006 | 09:42 AM
2001ramsport's Avatar
2001ramsport
yeah, common with these Ram's. there are no drain holes on the bottom side of the doors.(very ****-pour design)I just fixed both front door on my truck this summer. had to take both doors off,sand blast the rust,cut out the bad spots and weld in new metal. PS.I drilled some new drain holes on the bottom of each door.
Old Oct 14, 2006 | 07:22 PM
quadro's Avatar
quadro
I fixed mine when some idiot didn't know how to turn in the snow. I was lucky that he got the door that was rusted. now if someone would get the rear wheel well.
Old Oct 15, 2006 | 02:19 AM
JarheadX's Avatar
JarheadX
oh no...you got cancer...im sorry...
I had it too but I went thru ke-mo and sand blasted it down and got rid of it all, i had it on the drivers side
Old Oct 18, 2006 | 09:31 PM
DeadLifter's Avatar
DeadLifter
Mine just started. I'm gonna use Por-15 on it to seal it then in the spring I'm gonna use Durabak along the bottom for chip gaurd since it's already two tone.
http://www.getrust.com/
http://www.durabakcompany.com/index.htm
Old Oct 18, 2006 | 09:35 PM
Silver_Dodge's Avatar
Silver_Dodge
Poor mans fix is to spray it with WD-40. That can actually keep small areas of rust from spreading if it is not already underneath the paint too bad. It will get you by until you can get it fixed. Requires repeated application too as it drys out.
