12 inch e-fans
well i installed two 12 inch electric fans rated at 2100 cfm each. i put one fan on a electronically controlled thermostat and the other on a manual swith. with one fan on the temp with hover right about 210-220 somewhere in there, with both fans on it will run at about 200 even. so, what ive learned from this was that if you want your truck to actually run cooler, you need to have larger fans. i believe im going to switch the fans out and run a 16 inch and a 14 inch in the next few weeks. very simply task to do. thanks for listening...peace out
Steve-o
Steve-o
ORIGINAL: junkman306
Or you could change the thermostat to make it run cooler. Electric fans are only gonna free up horsepower.
most would have recommended 14"s or 16"s. if they are reversable fans, what you can do with one of them is put it in a pusher configuration and mount it in front of the condenser to help it out more. if nothing else, your A/C will be hella cold.
edit: oh yeah, you should make sure the temp controlled fan is on the drivers side... (you probably already knew that).
yeah i did put the temp control fan on the driver side....not because i knew that, but its just the way it worked out, imagine that. like i said though, hopefully a 180 thermostat will help, thanks guys.
