160deg. thermo.
Old Oct 14, 2006 | 10:51 PM
gypsum76's Avatar
gypsum76
Default 160deg. thermo.
A little while back I purchased an Accel tune-up kit from Summitt and also purchased a Hypertech 160deg. thermostat. I was thinking that since 160 is cooler than 180 so i purchased it. It was also a few bucks cheaper. Afterwards I noticed everyone here uses 180. since I have yet to install it, do I need to switch? Also, should I wait till I get a programmer?
Old Oct 14, 2006 | 10:54 PM
junkman306's Avatar
junkman306
Default RE: 160deg. thermo.
I think a 160 will be too cool. I got a 180 thermostat and noticed a slight difference in performance. I'd go with a 180.
Old Oct 14, 2006 | 11:20 PM
MAGICDSSMAN's Avatar
MAGICDSSMAN
160 is too cold. Your trucks pcm will keep dumping fuel in the motor and try and warm it up and after awhile you will get a check cel and your gas mileage will probubly go way down.
Old Oct 14, 2006 | 11:47 PM
gypsum76's Avatar
gypsum76
Thanks. I will try to return it, or something.
Will your programer work on a 98 5.9L?
Old Oct 15, 2006 | 04:18 AM
Racinfan83's Avatar
Racinfan83
160 is too cold like the other guy said. Hypertech thermostats are of questionable quality also. A couple guys on here have had problems with them. Go to NAPA and get their premium 180 degree stat. It is like $7. You can put in the stat before you get the programmer if you want.
Old Oct 15, 2006 | 12:19 PM
steve05ram360's Avatar
steve05ram360
180 deg is the best way to go and Napa is the best source.
