info on my oil pump
Old Oct 23, 2006 | 09:11 AM
turkeyhunter1962's Avatar
turkeyhunter1962
Default RE: info on my oil pump
OK, now I can understand why you mentioned the timing chain. Yes, if plastic pieces are found in the screen or bottom of the pan in the sludge I agree with you that the timing gear would need replaced or the oil fill screen will plug up again with more plastic.
When I replaced my 318 with the 360 I used a true double roller steel chain and gears without any plastic cover. As far as I know this is probably the best set-up when considering performance, reliability, and noise. I can be under the hood and barely hear any timing chain noise. I've attached a photo of my engine showing the timing gears and chain. Haven't had any experience with a total gear drive setup.
[IMG]local://upfiles/35230/4D69E57590F74CA986D9B76B6FE33168.jpg[/IMG]
