Cleaning o2 sensors
Old Oct 18, 2006 | 01:38 PM
steve05ram360's Avatar
steve05ram360
Default Cleaning o2 sensors
did you guys know that you can clean your o2 sensors? Get a can of CRC electronic components cleaner from your auto parts store, yank out the o2's front & rear (if the rears apply to your truck) and spray the tips of the sensor thru the slots/holes that are there for the air to get in and be read by the sensor. dont be stingy with it either. once your done, let them air dry for about 5 minutes or so then re-install. This has worked everytime for me. I think it should be a 30k maint. item for those who wrench on their trucks.
this MAY clear cat in-effeciency codes that the pcm has set. worked on my wifes dakota.
[sm=icon_cheers.gif]
Old Oct 18, 2006 | 05:28 PM
Racinfan83's Avatar
Racinfan83
Default RE: Cleaning o2 sensors
Do you have to use "electronic parts cleaner" or can you use something nastier like carb cleaner?
Old Oct 18, 2006 | 05:39 PM
Silver_Dodge's Avatar
Silver_Dodge
That's sounds good, except every time I have ever removed an 02 sensor, I had to buy a new one because it gets stripped in the removal process. Just a word of warning/caution to anyone planning to try this.
Old Oct 18, 2006 | 07:09 PM
kstroeher's Avatar
kstroeher
How much are new ones?
Old Oct 18, 2006 | 07:12 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: kstroeher
About $65.
One thing to point out is that O2 sensors have a sensative coating on them, so caution should be used when cleaning them. I think carb cleaner would eat that coating right off.
Old Oct 18, 2006 | 09:10 PM
JarheadX's Avatar
JarheadX
I think im gunna do that tomorrow...after I clean all the mud off my truck ;-)
