96 V10 idle issues
Old Oct 21, 2006 | 02:28 PM
pipedreams's Avatar
pipedreams
Default 96 V10 idle issues
My V10 has suddenly started to have idle problems.......idles so low it wants to stall. It runs fine in higher RPMS, but when you come to a stop often drops down low enough to stall. My first thought was vacuum leak, and probably still is, but I can't see anything obvious. Any ideas?
Old Oct 21, 2006 | 09:25 PM
DieselDemon's Avatar
DieselDemon
Default RE: 96 V10 idle issues
Put a vacuum gauge on it to be sure. Inspect your check valves.
Good luck.
Old Oct 22, 2006 | 01:15 AM
pipedreams's Avatar
pipedreams
Thanks, will do that for sure.
Old Dec 17, 2006 | 07:10 PM
CumminsV10's Avatar
CumminsV10
That same thing is happining to my 95 V10
Old Dec 18, 2006 | 12:33 AM
mntnceguy's Avatar
mntnceguy
Clean your throtle body and IAC (idle air control), sometimes basic tune up is in order as well. Usually just time to do some basic preventative maintenance and cleaning of the sensors
Old Dec 31, 2006 | 08:54 PM
CumminsV10's Avatar
CumminsV10
Thanks
Old Jan 5, 2007 | 01:53 AM
stormer426's Avatar
stormer426
new o2 sensors stopped my 95 V-10from doing that kinda wants ta die thing.
