what magnaflow cat did you guys use?
Old Oct 22, 2006 | 06:05 PM
johnjokela's Avatar
johnjokela
Default what magnaflow cat did you guys use?
i want to get the hi flow cats with single 02 sensors in them i think the part # is 94039 on magnaflow's website, that is for a 3 inch single o2 sensor cat, is three inch to big what is the stock size? seems im having a hard time trying to get hi flo cats with 02 sensors in them for my truck, iguess im not searching hard enough, what setup did you guys go with? NOT REGISTERED IN CALIFONIA, thanks i appreciate it very much,
Old Oct 22, 2006 | 06:41 PM
Mike Roma's Avatar
Mike Roma
Default RE: what magnaflow cat did you guys use?
Do you have stock exhaust? I think that's a single in/single out. I plan to use one of those when I get L/T headers, and 3" y-pipe. Summit has lot's of Magnaflow cats.
Old Oct 22, 2006 | 06:53 PM
johnjokela's Avatar
johnjokela
yeah stock as the manifolds and cats, but have new muff and tailpipe thats it
Old Oct 22, 2006 | 07:02 PM
Mike Roma's Avatar
Mike Roma
Well, my '96 has 2 in/1 out. The two inlets are about 2", and the outlet is 2 1/2". I'm not sure if yours is the same. Best bet is to take a look, and measure the pipe diameters.
Old Oct 22, 2006 | 07:08 PM
johnjokela's Avatar
johnjokela
i found a search on 02 simulators , so i will probally go that way , thanks though , now i know what to do!
Old Oct 22, 2006 | 07:11 PM
Mike Roma's Avatar
Mike Roma
Here's what Summit shows for an '01, 5.9. They only list 2500/3500, though. I don't know what you have.
http://store.summitracing.com/egnsea...3&autoview=sku
Old Oct 22, 2006 | 09:46 PM
JarheadX's Avatar
JarheadX
dude, dont waste ur money on 02 sims...just build it yourself it's easy. I actually deleted my cat and still don't throw a code.
Old Oct 22, 2006 | 10:43 PM
shott8283's Avatar
shott8283
depending on your states inspection.. you may have to keep your cat .. and its nice for everyone else...i have an 01 and i used a maganflow high flow cat from a 94 to 99 b/c i couldnt find one for a 00 and 01 .. worked great.. i welded everything but clamps will work.. also be a good time to give your 02's a good cleaning.. and inspect the wiring..i found one of my 02's with chaffed wiring and soon would be shorted out.. bad news.. unfortuantly i cant remember the part number but i know i got it from summitracing.com.... good place to get parts!!!!!!!!
Old Oct 22, 2006 | 10:49 PM
JarheadX's Avatar
JarheadX
Yeah if you look under my truck it looks like it is there, but I got connections ne ways
Old Oct 23, 2006 | 04:10 AM
silverram99's Avatar
silverram99
Yeah definently get the magnaflow replacement that comes with the Y pipe already. The universal one is actually more expensive for some reason.
