engines starts shaking when it gets hot...please help!!!
Old Oct 24, 2006 | 07:59 PM
david28's Avatar
david28
Default RE: engines starts shaking when it gets hot...please help!!!
What did u replace during the tuneup, as i said i replaced the plugs, wires, cap, and rotor
Old Oct 24, 2006 | 08:10 PM
steve05ram360's Avatar
steve05ram360
the o2 sensor should be in front of the cat, since yours is a '95, it'll only have 1, there will be no heater fuse for it, however if the wiring goes bad, (burnt, shorted, broken etc) your o2 will do funny things. I'd suggest swapping it anyway since it's never been done, then go from there.
do the basic tune up as well just to eliminate the easy stuff.
Old Oct 24, 2006 | 08:38 PM
nmason's Avatar
nmason
yep, plug wires cap and rotor. i think i just had a couple bad wires.
Old Oct 24, 2006 | 08:41 PM
steve05ram360
NMason, sorry i missed your Q about the o2 sensor... NGK is the way to go. Bosch dont seem to last too long in the rams.
Old Oct 24, 2006 | 10:54 PM
david28's Avatar
david28
ORIGINAL: asimpson97d
could be a torque converter problem too. buddy of mine had the same symptom and it turned out to be the converter.
did it do it at an idle??...anyone else seen this happen?
Old Oct 24, 2006 | 10:57 PM
shott8283's Avatar
shott8283
mine did when my tqc went.. and similar when the 02's got dirty.. i clean them with electrical parts cleaner every oil change..
be carefull with the 02's they are quite delicate and dont take to being handle ruff ... any CEL's???
Old Oct 25, 2006 | 01:09 AM
Big_N_Bad's Avatar
Big_N_Bad
hey man how long have you had this shake. Are you leaking any oil. We had a mustang that had a shake when it got warmed up. At first it wasnt anything but then it got worse. Then it started leaking oil. That verdict was a spun bearing in the shaft. But Do the other routine maint. first and use this as a last resort. Hopefully this isnt it, as it isnt a cheap repair but if it is Itll give ya a reason to install some performacne parts.
BNB
Old Oct 25, 2006 | 03:45 AM
david28's Avatar
david28
CEL's???
ORIGINAL: shott8283
Old Oct 25, 2006 | 04:11 AM
silverram99's Avatar
silverram99
Check Engine Lights, also known as MIL (Malfunction Indicator Lights).
Old Oct 25, 2006 | 09:13 PM
david28's Avatar
david28
no CEL's showing up, does that rule out the o2 sensor?
