EUREKA!!! 11-12-2006
Old Nov 8, 2006 | 12:57 AM
  #101
Gary-L's Avatar
Gary-L
Veteran: Navy
Default RE: Buttoned Up - Starting Issues
Well, driving home it kept cutting in and out. It's not killing it, the truck just has a funky quaking to it. I am positive that it's the engine. The CEL light came on, but my code reader couldn't pull anything. I cleared the code (funny since the code reader couldn't find it). We'll see what happens when I drive to work tomorrow.
Old Nov 8, 2006 | 01:23 AM
  #102
steve05ram360's Avatar
steve05ram360
well since it's not running right, maybe you should consider testing the crank/cam sensors to see if one could be flakey. on the cam sensor you could have pinched a wire causing a problem with it.
Old Nov 8, 2006 | 11:41 AM
  #103
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: steve05ram360
I started the truck this morning, and right away the CEL illuminated. It shuttered all the way to work and when I got here I connected the code reader and pulled a P1391. Looks like I need to do some checking on those two sensors and the associated wiring.
Other than that, the truck runs like a dream.
Old Nov 8, 2006 | 01:18 PM
  #104
steve05ram360
p1391??? huh? my obdII list says "Glow Plug Circuit Low Input Bank 1"...
Old Nov 8, 2006 | 01:20 PM
  #105
Gary-L's Avatar
Gary-L
Veteran: Navy
P1391 - Intermittent Loss of CMP or CKP.
Old Nov 8, 2006 | 01:28 PM
  #106
steve05ram360
ok, so my list is not applicable to all obdII setups... [&:]
yeah, sounds like you get to crawl onto your motor again
Old Nov 9, 2006 | 12:37 PM
  #107
Gary-L's Avatar
Gary-L
Veteran: Navy
Your list is compatible with OBDII. The P1391 is a Chrysler specific code. Anyway, I jumped into the engine last night, burnt the **** out of my hand removing the Crankshaft Sensor (with the aid of my son) and found that the end was a bit greasy/dirty. I inspected the harness and found no evidence of broken insulation. So, I throughly cleaned the sensor in my solvent tank, wrapped the wire that is close to the sensor in electrical tape, and then taped the convolute in place so that the harness is protected as is runs out of the transmission.
Now, when I drive at low speeds everything seems fine. Once I get above 50mph, there's still some jerking and even some popping coming from the engine. This is noticeably pronounced when I have Overdrive turned off. When Overdrive is engaged, the jerking isn't as bad. I am thinking that I could have one or two bad injectors. I drove all the way to work today (75mph on the Interstate for 35 miles) and the CEL did not illuminate. I'm wondering if the TPS is creating noise that's interfering with the transmission, or is it still in the engine? I have the plug wires all routed properly and covered with convolute. I am confident they are set right and there are no misfire issues. I am wondering if the timing may be a bit off.
Old Nov 9, 2006 | 01:20 PM
  #108
steve05ram360
you can test the injector coil resistance and then put a mechanics stethescope on it and hear if it's actuating or not. if it is then it should be fine. dirty however you would not be able to tell... when you reset the pcm the 1st time, how long was it before the codes came back? you may not have enough miles on it yet to set the code since the last pcm rest.
timing is controlled by the pcm off the crank sensor. my suggestion is to have a look at the cam sensor next... it is responsible for the injector timing. if you know anyone who has a magnum motor that would let you borrow the 2 sensors for a day or 2, swap them out. a wrecking yard may also be a good place for cheep debugging parts. they wont guarentee them but it's worth mentioning. we have a company here called pick-n-pull that sells stuff off cars hella cheep. you might try to find a yard like that local...
Old Nov 9, 2006 | 01:38 PM
  #109
Gary-L's Avatar
Gary-L
Veteran: Navy
Those are my next steps, Steve. Actually, I've got a guy at O'Reilly Auto Parts who gives me freebies and takes care of me. He ordered a Camshaft Sensor for me last night so I can look at it. Chances are he might let me try a new sensor (or two) to see if either is the deal and return them if they aren't. When I last reset the PCM, the truck sat overnight. I'm thinking maybe disconnecting the battery for a few hours could be the next step? I am also headed to Illinois over Thanksgiving, and my dad has a junkyard source who can hook me up as well.
I'll report back my findings.
Old Nov 9, 2006 | 02:50 PM
  #110
steve05ram360
try the distributor move 1st...
thanksgiving??? dude that's 2 weeks away... you need to figure this out asap. WE (dodge forum) cant have you driving to Illi with a popin & clankin truck lol.
