EUREKA!!! 11-12-2006
Old Oct 28, 2006 | 06:35 PM
  #51
steve05ram360's Avatar
steve05ram360
Default RE: Buttoned Up - Starting Issues
does your haynes manual show the routing?
Old Oct 28, 2006 | 06:46 PM
  #52
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: steve05ram360
I have been studying it. It's not very clear. Imagine that.
Old Oct 28, 2006 | 06:59 PM
  #53
steve05ram360
what about the emissions lable in the front of the truck?
I was looking further at the evap setup in the manual and the 2 canisters on the frame rail are also to be considered in all this. one thing i could suggest is getting your digital camera and finding a '97 on a lot and go snap some pics of the evap setup. maybe that will shed some light on it.
Old Oct 28, 2006 | 07:01 PM
  #54
steve05ram360
ORIGINAL: VWandDodge
OK, this is making sense now. My evap/purge solenoid is located on the driver's side rear of the intake. I might have the line from the throttle body (hard plastic) and another line from *somewhere* installed backwards on it.
your missing the vacuum line off the TB... is it off for a reason in this pic? the one next to the map sensor
Old Oct 28, 2006 | 07:25 PM
  #55
Gary-L's Avatar
Gary-L
Veteran: Navy
It took me a while to find vacuum line to fit that. Yes, it was off on purpose in this picture as I was preparing to replace it.
Now, I swapped the two lines on the Evap Purge Solenoid to see what would happen. Now, if I press the throttle to 2K rpm, it holds without fluctuating. That's the good news. The bad news is that acceleration isn't that impressive, I top out around 75mph going up a mild grade (mild struggling) and the vent line *STILL* spouts gas. Once I loosen the gas cap, pressure is released and the drainage stops.
I was wrong earlier, when pressure is relieve it is a vacuum type pressure.
I am also wondering if perhaps my catalytic converter is clogged. Before I removed the engine, the truck had a very difficult time making mild grades and the converter would rattle. Looks like I am making ground, but I am still stumped.
Old Oct 28, 2006 | 07:31 PM
  #56
silverram99's Avatar
silverram99
You might look at your timing too, if its not set correctly you will loose power like you are describing. Also it sounds like your converter may be clogged, do you have an IR thermometer? If so you can test the cat, temperature should be hotter on the outlet side than the inlet, if they aren't the cat is bad.
Old Oct 28, 2006 | 07:36 PM
  #57
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: silverram99
I don't have an IR thermometer, but I should get one. I am now waiting for the truck to cool down so I can verify the position of #1, set it, adjust the distributor, lock it down, and then route the plug wires. I can go to a muffler shop I know, on Monday, and have them shoot the cat.
Old Oct 28, 2006 | 07:43 PM
  #58
silverram99
I can't say enough about how handy my IR thermometer is, the best part was I didn't pay anything for it. I had a friend who worked at Auto Zone some guy bought one and they ordered it but he never came back to get it. It hung around for 6 months and I noticed it and he gave it to me. It's a Raytech, same one my uncle got off the Snap-On truck and probably paid way too much for lol.
Old Oct 28, 2006 | 07:48 PM
  #59
Gary-L's Avatar
Gary-L
Veteran: Navy
I would still like to know why in the hell fuel is coming out of the vent. This is pissing me off [:@]
Old Oct 28, 2006 | 07:57 PM
  #60
silverram99
Where are you at in Oklahoma? I'm really close to the Oklahoma/Kansas line and would probably be alot more help if I could look at it rather than just try to think of things.
