leaf spring block lift ?
Old Oct 25, 2006 | 06:49 PM
Silver_Dodge's Avatar
Silver_Dodge
Default RE: leaf spring block lift ?
It gets inserted above the bottom most leaf, but under the leaf pack. And yes, new u-bolts will be a must.
Old Oct 25, 2006 | 07:05 PM
JD770's Avatar
JD770
ORIGINAL: Ram_Sport
how do u put an aal on? just set it on the bottom of the leaf pack and crush it down redo the ubolts and tada?
generally, you jack up the vehicle, support it, droop the axle, remove the spring pack clambs, and the center pin bolt, insert leaf spring where it should be and re-assemble.
most either go on the top or the very bottom, the longer the Adda leaf the better the ride will be.
