waterpump o-ring
Old Oct 25, 2006 | 06:56 PM
ddog737374's Avatar
ddog737374
Default waterpump o-ring
In the past year I have gone through 3 small water pump O-rings on the side on the water pump where the small 1/2 or 3/4 inch hose comes out and i dont know why it is eating them up so bad anyone have anyideas what i can do?
Thanks Dan
Old Oct 25, 2006 | 07:14 PM
FRUITPORTCAT's Avatar
FRUITPORTCAT
Default RE: waterpump o-ring
Only time i've seen them bad is if the pipe is not bolted in place. There should be a mount tab on the pipe to hold it in place.
Old Oct 25, 2006 | 07:16 PM
steve05ram360's Avatar
steve05ram360
you can also look for a nic in the bore... if there if anything in there to cut the o-ring, vibration will eat it up over time.
Old Oct 25, 2006 | 07:23 PM
ddog737374's Avatar
ddog737374
yea everything is bolted in fine and it looks smooth. the o-rings will work tell about 5,000 miles and the are craked and split and causes a leak so im thinking something in the coolant is eating it i dont know
Old Oct 25, 2006 | 07:28 PM
steve05ram360
does your motor run hot? 5k is a very short life for an o-ring...
Old Oct 25, 2006 | 08:07 PM
FRUITPORTCAT
Are you using just a plain black rubber o-ring or the white teflon type o.e. ring ?
Old Oct 25, 2006 | 10:04 PM
silverram99's Avatar
silverram99
You might get some of that paint on teflon sealer and coat the end that goes in before you install the next O-ring. I usually do that when I do a water pump on our trucks, not sure if it does anything really butI haven't had one leak yet. (Knock on wood.)
