1500 Tranny
It's a 46RE.
Found some information here: http://dodgeram.org/tech/transmission/4xrh.htm
No info on the 46 but the 47 is only rated for 450 lb/ft so the 46 would be less than that.
(Man, that seems low)
Any hard numbers would be pure speculation. I'm reading that the 46RH/E is an A518 which is a 727 (Torqueflite) with overdrive added. Considering that the 727 was put behind some of the most powerful muscle of it's era, I can't believe that it would rate THAT much less than the 47RH/E.
From the "Tell Me It Ain't So" file ... in 2002, Dodge replaced the 46RE with the 45RE in the 1/2-ton Rams?? They DOWNGRADED the tranny?? [>:]
