4.10s optional in '98
Old Oct 30, 2006 | 07:55 PM
Matt Harwood's Avatar
Matt Harwood
Default 4.10s optional in '98
I was poking around under the hood of my Ram today and noticed the options sticker listed a 4.0/4.1 axle ratio (I assume front/rear). Does my truck have 4.10s already installed? If so, I can't imagine someone trying to drive this thing with stock 3.55s--what a slug! For reference, I cruise at about 2000 RPM @ 60 MPH in OD.
Also, on an totally unrelated topic, how easy is it to replace the rear seal on the transfer case? Mine has a leak that is making a mess on my driveway. I'm going to pull the driveshafts for new U-joints sometime soon anyway.
Thanks!
Old Oct 30, 2006 | 08:31 PM
blazelefty7's Avatar
blazelefty7
Default RE: 4.10s optional in '98
I have the stock 355s and run about 1800 rpms at 65mph.
Old Oct 30, 2006 | 08:41 PM
dillonjm's Avatar
dillonjm
And my 3.9whatevers run just under 2k @ 60mph. So, 2 or slightly over 2k (assuming we have the same tire size) would be close to 4.10's
Old Oct 31, 2006 | 01:05 AM
Tani1500's Avatar
Tani1500
the rear seal is easy to replace. can do it right in the truck or take it off. ( i think its easier to take it off since its 4 bolts. then put it in a vise and use a hammer and screw driver to pop the old one out. then tap the new one in.
