Tranny pan gasket = easy job?
Old Nov 2, 2006 | 11:07 AM
Ram Man 98's Avatar
Ram Man 98
Default Tranny pan gasket = easy job?
While stocking up at Dodge, I picked up some ATF+4, a new tranny fluid filter, and they sold me a ridgid plastic gasket for the tranny oil pan. They said the stock one is no good, and it should have this plastic one. Has anyone changed this? Should I be applying a seal with something like "gasket maker in a tube" to their gasket? Is this one of those projects that makes you curse and go crazy?? Thanks boys!
Old Nov 2, 2006 | 11:39 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Default RE: Tranny pan gasket = easy job?
Get the actual rubber reinforced gasket. It's an easy, but messy, job.
Old Nov 2, 2006 | 12:10 PM
Silver_Dodge's Avatar
Silver_Dodge
If the gasket they have you is the one I am thinking of, it is a very good gasket, and easy to install.
Old Nov 2, 2006 | 06:26 PM
silverram99's Avatar
silverram99
Don't use any kind of sealer. There is no need for it because a tranny gasket will seal fine and the built up material from the sealer is one more place that could cause the gasket to leak.
Old Nov 2, 2006 | 07:41 PM
Ram Man 98's Avatar
Ram Man 98
Great ! sounds like I will take it on! Thanks
Old Nov 2, 2006 | 07:45 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: Ram Man 98
Make sure you torque the bolts in at the correct specification.
