clanking noise
Old Nov 2, 2006 | 08:22 PM
dirty dog's Avatar
dirty dog
Default clanking noise
ok guys on my way home today i had my radio turned off and i floored the gas and i heard a clanking noise and it was bothering me so i did it again at the next stop sign it did it again so when i got home and i put it in park i stomped the gas again and this time i didnt hear it so it must be something in my transmission so my question is im getting the trans serviced in a couple weeks and going to have the bands adjusted is this going to fix my problem?
Old Nov 2, 2006 | 08:53 PM
ChaoticBastard's Avatar
ChaoticBastard
Default RE: clanking noise
That could be SO many things.First,What year ram?What drive?4x4?
Old Nov 2, 2006 | 09:13 PM
dirty dog's Avatar
dirty dog
its a 2000 4x4 1500
Old Nov 2, 2006 | 09:56 PM
Scottr1110's Avatar
Scottr1110
check ur rear ujoints because i had this weird noise that would only happen when giving it gas and it turnout to be a worn out rear ujoint replaced it and it stoped sounded like clanking sorta
Old Nov 2, 2006 | 10:12 PM
dirty dog's Avatar
dirty dog
i was thinking trans because i have 37" tires and it only happens at wot
Old Nov 2, 2006 | 11:11 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
To see if it's your U-joints, start the vehicle, put your foot on the brake and then shift into drive. Then, shift into reverse. Do this a few times and if it "clunks" then it's your U-Joints.
Old Nov 2, 2006 | 11:45 PM
DADDIEMIKE's Avatar
DADDIEMIKE
POSS. COULD BE THE INTAKE VALLEY PAN GASKET IF IT IS ONLY HAPPENING AT WOT. WHEN UNDER LOAD THE ENGINE IS SUCKING IN OIL FROM THE INTAKE VALLEY AND DETONATING AND MAKING A ROD KNOCK.
Old Nov 3, 2006 | 04:14 PM
dirty dog's Avatar
dirty dog
ok guys today i put on a k&n filter and took my tb off and cleaned it a put in a bottle of seafoam and when i looked in the intake manifold it had oil in it and my throttle body plates had oil on them especially on the underside so im thinking of getting the stage 2 intake manifold from hushes and it comes with his plenum gasket deal
so i guess i can go and check the u joints later
Old Nov 3, 2006 | 05:54 PM
DADDIEMIKE's Avatar
DADDIEMIKE
SOUND LIKE THE FAMOUS INTAKE LEAK STRIKE AGAIN
