Max lift on stock heads
Old Nov 5, 2006 | 12:38 AM
05SilverHemi's Avatar
05SilverHemi
Default Max lift on stock heads
I would like to know if anyone knows what the max valve lift can be on a set of stock magnum heads. This is completely independent of the valve springs which will be replaced the match the cam when it is purchased.
For example the GM Vortec head in stock trim has a max lift of .480" before you need to do machine work to clearance for more lift.
Thanks!
Old Nov 5, 2006 | 09:32 AM
DADDIEMIKE's Avatar
DADDIEMIKE
Default RE: Max lift on stock heads
go to www.mmeracing.com and ask mark.
