how would you.....
Old Nov 9, 2006 | 02:52 AM
974x4's Avatar
974x4
Default how would you.....
find out if you had a 5.9L magnum in a 97? or are they all magnums. was looking at this website http://en.wikipedia.org/wiki/Dodge_Ram#Engines_2 and from what i could tell, the engines are jus magnums. i know i can probably look the vin number up but i do not know where to look it up at....
Old Nov 9, 2006 | 02:53 AM
Silver_Dodge's Avatar
Silver_Dodge
Default RE: how would you.....
They are all Magnums from 94-01. I think maybe even earlier then '94 in some of the first gen Rams.
Old Nov 9, 2006 | 03:05 AM
974x4's Avatar
974x4
http://cgi.ebay.com/ebaymotors/NEW-D...55124697QQrdZ1
thxs
Those heads for sale would work then? Is there a difference in the combustion chamber on a 5.2 and 5.9head? or are they both the same CC's???
Old Nov 9, 2006 | 12:40 PM
Socha_62's Avatar
Socha_62
5.2L = 318ci
5.9L = 360ci
I don't see how these heads could fit both, I think the person that listed them either A) doens't know theres a diffrence, or B) is just trying to pawn them off to somebody knowingly that they won't work.
Old Nov 9, 2006 | 12:54 PM
nihlcat's Avatar
nihlcat
A write up from wikipedia on the Magnum line.
http://en.wikipedia.org/wiki/Dodge_R...2FBE.27_Trucks
Not that it helps, but here's VIN codes
http://dodgeram.org/tech/specs/VIN_decode.htm
Old Nov 9, 2006 | 01:06 PM
steve05ram360's Avatar
steve05ram360
the heads are the same from 5.2L to 5.9L they look like they should work, what are the specs on them?
Old Nov 9, 2006 | 02:08 PM
steve05ram360
oops forgot to mention... look on the block above the starter. the motor size is stamped on the block.
[IMG]local://upfiles/1508/1850DFB4F20442C78A53ED718677F3C3.jpg[/IMG]
