Air Bag suspension brackets
Old Nov 11, 2006 | 12:19 AM
Jimmeh's Avatar
Jimmeh
Default Air Bag suspension brackets
Has anyone else had them break off the frame, causing a crack? I drove that truck today, and that is what seems to have happened. I am trying to determine what may have caused it.
Also, if any of you have had them break, did you replace it, or just weld it back together?
Old Nov 11, 2006 | 12:21 AM
ryans590's Avatar
ryans590
Default RE: Air Bag suspension brackets
what broke/cracked? the frame where it was bolted or the bracket its self..what brand are they? firestone? ive seen one set of those do it...they wernt installed corectley and the truck was grosley overloaded it "pulled" the bolts throug the frame
Old Nov 11, 2006 | 01:08 AM
shott8283's Avatar
shott8283
not sure what you exactly talking about.. maybe if you could snag a pic and post it then maybe we could give advice on if it should be welded or replaced.. if it were me..regardless on what it was.. id weld it.. i dont have brand spanking new miller 210 sittin in the shop for nothing!!!!!
Old Nov 11, 2006 | 02:56 AM
Jimmeh's Avatar
Jimmeh
Where the bracket crosses the frame is where it was broken, plus the crack in the frame. My buddy who is selling the truck things that the original owner was pulling something on the drivers side of the truck, putting too much stress, but I don't think that would cause something like that. I'll try and get a picture Monday. Either way, a little bit of welding, and I think the bracket and the frame will be fine.
Old Nov 11, 2006 | 04:51 AM
ryans590's Avatar
ryans590
yah pics would help a lot...if the frame is cracked youll half to weld it. if its a vetical crack you should fish plate too horizonal you should be ok....of cource the BEST fix would be replacing the bracket however its all a matter of how much you want to spend, and how good of welder you are.... and if your like shott whos roling in the dough buying new welders and all...
