98 Dodge Ram Question
Old Nov 15, 2006 | 12:11 AM
jonathanstimm's Avatar
jonathanstimm
Default 98 Dodge Ram Question
MY 98 RAM 1500 V6 WITH 84000 MILES IS SPUTTERING AND WILL NOT GO OVER 20 MPH WITH OUT ALMOST DYEING ON ME HAS ANYBODY ELSE HAD THIS PROBLEM OR CAN ANYONE SUGGEST WHERE I SHOULD START MY TROUBLESHOOTING?
Old Nov 15, 2006 | 12:16 AM
jonathanstimm
Default RE: 98 Dodge Ram Question
BUMP
Old Nov 15, 2006 | 12:27 AM
TMS Bill's Avatar
TMS Bill
No CEL? No codes?
Blocked cat ... dirty TPS ... bad gas.
What were the circumstances around when it started doing this?
Old Nov 15, 2006 | 01:56 AM
Socha_62's Avatar
Socha_62
ORIGINAL: jonathanstimm
BUMP
[sm=happybounce.gif] After 5 minutes?!
Anyways like TMS said, either fuel pump isn't putting out good presure or your cats clogged. My money is that the cat is clogged. Crawl under and take out the O2 sensor BEFORE the cat and start it up. See if it will idle better, usually that hole the O2 was in will let out enough exhaust so you can tell if thats the problem.
habeba86's Avatar
habeba86
ORIGINAL: TMS Bill
No CEL? No codes?
Blocked cat ... !!!!?
Old Nov 15, 2006 | 03:34 AM
racing_dave's Avatar
racing_dave
i had the same exact problem. i took the exhaust off. and took a bar up the cat and blew it all out and its running a lot better
Old Nov 15, 2006 | 02:58 PM
jonathanstimm
Thanks for the advice guys. My first thought was that it was the cat I just didn't check it yet but now I am going to. Sounds like a pretty simple fix.
