Brakes Help!!!!
Old Nov 16, 2006 | 04:06 PM
rydog2624's Avatar
rydog2624
Default Brakes Help!!!!
I have a 2001 dodge ram 1500, i decided to change my own front brakes so i did all the required steps according to my hayne's manual. I then get in my truck to pump the brakes until they are stiff then I turn the ignition on and my brake pedal becomes very loose to the point to stop i have to completely push the pedal down. should i bleed the brakes?
any help would be appricated
Ryan
Old Nov 16, 2006 | 04:17 PM
Ram Man 98's Avatar
Ram Man 98
Default RE: Brakes Help!!!!
Which components of the brakes did you change? Did you disconect the brake line?
Old Nov 16, 2006 | 06:41 PM
Racinfan83's Avatar
Racinfan83
If you unhooked any brake lines or popped the pistons out of the calipers you will need to bleed them. I make sure not to unhook anything when I change pads - so I don't have to mess with bleeding them......
Old Nov 16, 2006 | 10:32 PM
DieselDemon's Avatar
DieselDemon
Like racinfan said, if you disconnected the brake line, you will have to bleed the system. If you popped a caliper piston out, then no one ever told you not to step in the brake pedal if your calipers are hanging.......LOL.
There is also the possibility that a check valve or vacuum hose is loose/bad.
Good luck.
Old Nov 16, 2006 | 10:37 PM
mopar98's Avatar
mopar98
check the bleeders and make sure there tight .
