Power Wire-- Awesome
Old Nov 20, 2006 | 04:06 AM
  #31
bcdalton's Avatar
bcdalton
Default RE: Power Wire-- Awesome
MAGICDSSMAN-- Thanks for the response and clarification.
Old Nov 20, 2006 | 04:15 AM
  #32
bcdalton's Avatar
bcdalton
timwag2001-- Thanks for responding regarding the MSD Kit. This information helps me in deciding whether to purchase it or not. Sounds like a mod that will definitely help with the performance of my truck. Thanks for your knowledgeable advice. I'll be adding that mod to my list to purchase. Do you know roughly how much the MSD Kit runs for and where to buy it from? I greatly appreciate it. Thanks!
Old Nov 20, 2006 | 01:39 PM
  #33
steve05ram360's Avatar
steve05ram360
ORIGINAL: MAGICDSSMAN
Maybe I can help clear this up a little bit. The power wire does not make the computer think the engine is 20 degrees cooler. The power wire is similar but not the same thing as the resistor mod. The resistor mod shows the same temp all the time where the power wire reduces the intake air temp the cmputer see's by 20 degrees. Our obd2 engines uses all of the sensor readings to help determine the timing. If the pcm thinks the air intake temp is 20 degrees cooler the timing will be slightly more advanced. This is probubly the main reason for the increase in performance not necesarily the increase in fuel.
This is how I understand it. If I am wrong somebody please correct me.
this is very true... also you could easily do the same mod yourself with a $1.00 radio shack resistor... all you would need to do is look up the IAT temp table and find out how much of a resistor you would need to put in line with the wire going back to the PCM. then you are offset by that value. if you find 20 deg is too much, adjust the value. you could also put a pot in there to tweek until you find the value you prefer.
Old Nov 20, 2006 | 03:10 PM
  #34
Tani1500's Avatar
Tani1500
ORIGINAL: bcdalton
Look in the DIY section, Shotts did a great write up about installing the MSD box and blaster coil
Old Nov 20, 2006 | 07:20 PM
  #35
timwag2001's Avatar
timwag2001
i'ld go right to msdignition.com. i really dont know the pricing or if you can get it cheaper elsewhere
Old Nov 20, 2006 | 09:29 PM
  #36
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: timwag2001
he also has a fastman... which means more air and more gas. with a msd ignition it would probably kick some serious ***.
its almost like the iat mod from the v8 perfomance website.
true, sounds like fun!
Old Nov 20, 2006 | 10:11 PM
  #37
kevo2k6's Avatar
kevo2k6
here's something to think of. i would like to get someone who has more knowledge than me to help me on it though. If you have mods on your truck, such as a larger throttle body and ported manifold, maybe ported heads etc. then they cause your to run lean correct? well wouldn't things such as the power wire or resistor mod help correct the lean conditions by increasing the fuel ratio?
Old Nov 21, 2006 | 01:40 AM
  #38
bcdalton's Avatar
bcdalton
Tani1500-- Thanks for the tip and response. I'll check out Shotts' write up.
Old Nov 21, 2006 | 01:47 AM
  #39
bcdalton's Avatar
bcdalton
timwag2001- Thanks for the website. Checked it out and got some good information regarding the ignition mod. I will definitely be getting the MSD in the near future. Thanks for the help.
Old Nov 21, 2006 | 01:54 AM
  #40
dsertdog56's Avatar
dsertdog56
BTW...you can usually get that desired "20 degree" temp change by relocating the IAT to the air intake or filter body.
Ebay is full of these things, but I'll stick with Hughes performance advice and avoid them, for now.
http://www.v8performance.com/tipsand....htm#timingkit
