LED's
Old Nov 21, 2006 | 01:52 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Default LED's
Since I know my headlamp switch rheostat burned out (no running lights, dash lights, or foglamps), I decided that I want to replace all bulbs in my truck with LEDs. I prefer LEDs as they are brighter and use less energy. I am one who does not drive with the dash lights at full intensity.
Anyway, has anyone else here replaced any of the lighting in his truck with LEDs? This is a source that a friend gave me: http://www.superbrightleds.com/cgi-b...?product=OTHER
Old Nov 21, 2006 | 04:33 PM
steve05ram360's Avatar
steve05ram360
Default RE: LED's
I just installed an accessory led light over my cup holder... couldnt see it at night so I figured a $2 white led from Rad shack would do the trick. put a 680 ohm resistor in line with it and it looks sweet. 1 led did the trick. I would suggest a 470 ohm resistor in line with each led.
Old Nov 21, 2006 | 04:48 PM
ASH's Avatar
ASH
Default RE: LED's
I'm have limited knowledge when it comes to electrical components. Why do you recommend installing the resistor?
Old Nov 21, 2006 | 04:50 PM
steve05ram360
Default RE: LED's
limits the current to the LED which dims the brightness. the brighter they are, the shorter the life.
Old Nov 21, 2006 | 04:56 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Default RE: LED's
They should have resistors in them if they are made to replace current automotive lights. Otherwise, how do you wire in the resistors?
Old Nov 21, 2006 | 07:06 PM
steve05ram360
Default RE: LED's
if they do, they are still to bright for my tastes... If I had a digital camera I could take a pic. both girls who had digitals move out so i'm looking for a used one myself (nikon d200).
the resistors are soldered inline on either the positive or negative terminal... doesnt matter which. I built a mini harness of sorts so I could easily remove it if I prefered the "without" look. I used a short piece of wire soldered to short ends of the resistor body and taped it up... then crimped spade lugs on each end one male & 1 female... did it so all I had to do is yank it out and plug in the one end to the guage.
Old Nov 21, 2006 | 07:15 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Default RE: LED's
ORIGINAL: steve05ram360
Are you saying you're an old fart?
Thanks for the tip. When I get back from my trip I'll let you know what I find in the area of LEDs.
Old Nov 21, 2006 | 07:23 PM
jakebrake's Avatar
jakebrake
Default RE: LED's
I've been searching for sometime, found taillights for the 2nd gens finally. Haven't ordered them yet, but here's a pic
Old Nov 21, 2006 | 07:38 PM
steve05ram360
Default RE: LED's
ORIGINAL: VWandDodge
Old... yes... fart, maybe... depends on what was for lunch [sm=icon_rofl.gif]
Old Nov 21, 2006 | 07:45 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Default RE: LED's
ORIGINAL: jakebrake
Weblink?
