Adjusting Headlights
The headlights on my truck seem to point way to far up, and don't shine on the road at all. How do I adjust them to shine on the road? Any help would be appreciated!
I need to do this to mine. Headlights have a simple adjustment screw on them that just needs to be turned. As for location I'm not to sure since I haven't looked it up yet. If you download the FSM from the merry christmas thread I'm sure that will have the location and how to do it! Good luck
On my 2000 Sport there is a torx screw just below the headlight that controls the up-down adjustment.
Looking at the headlight from the front...look just below and under and you can see it.
There is another one just for changing side adjustments too. It is a small Torx bit - maybe a 15-20) It is easy to do- try using your garage door as a guide, but stay far enough back for an accurate adjustment. ( you do not want to blind passing drivers)
