brake help??
Old Nov 23, 2006 | 04:15 AM
ddog737374's Avatar
ddog737374
Default brake help??
Well I was driving home from off-roading in the mountains and im sure my brakes got hot but anyways when i got back to town i had to stop fast my my brakes looked out and skidded for a second and then stoped what is going on ?
it now does it ever time i have to stop hard
Thanks Dan
Old Nov 23, 2006 | 07:55 PM
DieselDemon's Avatar
DieselDemon
Default RE: brake help??
Misadjusted brakes is always possible. Drum could have warped enough to create a hard spot, which helps makes easier to lock the wheels. What was the year, model, etc. rear wheel / 4 wheel anti?...etc.
Thanks.
Old Nov 23, 2006 | 08:19 PM
ddog737374's Avatar
ddog737374
its a 97 dodge ram 1500 but when i took out todrive today its fine. the only thing i can think of is the brakes got to hot? i had to use the brakes a ton on the way down could that cause it?
Old Nov 23, 2006 | 08:58 PM
DieselDemon
Absolutely they could have been cherry red. If all is fine then, keep chuggin'. Or drop the drums and take a look. Make sure the shoes are not cracked.
Good luck.
Old Nov 24, 2006 | 10:13 AM
mayhewcfi's Avatar
mayhewcfi
Just for future reference. I think the worst thing for brakes is to ride them for a long time like when you are going down a really long hill. When I drove up Pike's Peak a few years ago they had check points on the way back down where they would check to see if your brakes were getting hot. If they were too hot, they would make you wait till they cool and give you some advise on how to prevent further problems.
The best way to limit your speed going down a long hill is to shift to a lower gear and let the engine slow you down. As long as you don't overrev the engine you will not do damage to it and you will extend the life of you brakes.
