Differential Fluid
Old Nov 24, 2006 | 02:49 AM
ddog737374's Avatar
ddog737374
Default Differential Fluid
ok well im going be changing my gears out with 4.56 and i was thinking what do u guys think the best Differential Fluid is ?
Thanks Dan
Old Nov 24, 2006 | 11:26 PM
Racinfan83's Avatar
Racinfan83
Default RE: Differential Fluid
I use Mobil 1 synthetic 75W 90 in mine. You might want to go with the 75W 140 with that low of a gear or if you tow a lot. Remember to add "friction modifier" to the rear diff if you have limited slip.....
