Help Removing Muffler
Old Jul 16, 2008 | 12:52 PM
Cereal Killer's Avatar
Cereal Killer
Default RE: Help Removing Muffler
ORIGINAL: Sehr916
I bought a FM 50 series SUV and it doesn't look like its going to fit with the stock piping. What should I do to make it fit (length wise)?
Thank you
Sorry, I didn't see this the first time. Just buy some extension pipe at an autoparts store. Oneend will beflared a little bit to fit over the pipe. the other end will be the same size,so it will fit in your mufflers inlet.
Old Jul 16, 2008 | 01:59 PM
94Ramsey's Avatar
94Ramsey
i got my muffler off useing a 12yr old oak tree, a tow strap and 1st gear.
Old Jul 16, 2008 | 03:20 PM
Sehr916's Avatar
Sehr916
Thanks Cereal Killer. Im going to use a hacksaw on the other side now, but how do you recommend getting the output/input shafts off of the other pipes?
I think I read in an old post by you that you just used a hammer and chisel?
As for extension pipes, would I need 2.5" to match up?
Thank you a lot
Edit: I'm going to run to autozone and rent an exhaust pipe cutter and pipe expander to get the crimps out? Will that help??
Thanks again
