VSS diagnosis/symptoms
Old Nov 26, 2006 | 02:24 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Default VSS diagnosis/symptoms
I left my Haynes at my parents' this last weekend and can't get it until December. I paced someone in my truck and discovered (like I thought) that my speedometer is about 5 - 10mph off). I want to be sure it isn't the VSS that's bad before I take it to a speedometer repair place and have them inspect the gears. Can anyone give me some tips to test the VSS or explain how I know if its bad? No trouble codes are being thrown right now, so that option is ruled out.
Old Nov 27, 2006 | 11:15 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Default RE: VSS diagnosis/symptoms
None of you has anything to offer? Here's something else -- I have 16" wheels on my truck but I need to double check the tire size. Where can I determine what the stock wheel size is for my truck to ensure I don't have tires that are throwing the speedometer off?
Old Nov 27, 2006 | 11:19 PM
mopar98's Avatar
mopar98
Look inside the driver side door for the tire size should be there .
Old Nov 28, 2006 | 09:59 PM
TMS Bill's Avatar
TMS Bill
IIRC ... the `97s still used the gear in the tailshaft trick to run the speedo, didn't they? I know that `98s dispensed with that and use the rear wheel speed sensor.
Wheel size won't affect speedo calibration. TIRE size will. I believe that the speedometer is calibrated for 245's which is the stock tire (although some came from the factory with 265's ... mine did).
Old Nov 29, 2006 | 01:00 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: TMS Bill
Just for clarity - rim + tire = wheel
But I know where you're going with that. I haven't had time to check what size tire I'm running right now. I will in a couple of days.
Old Nov 29, 2006 | 01:26 AM
timwag2001's Avatar
timwag2001
I have 16" wheels
clearly sounds like a tiny *** wheel
Old Nov 29, 2006 | 01:41 AM
TMS Bill's Avatar
TMS Bill
ORIGINAL: timwag2001
I have 16" wheels
Well ... that for damn sure explains the speedometer calibration problem ...
Old Dec 17, 2006 | 04:25 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Just got around to remembering to check what size tires my truck is rated. 225/75R16, which is what is mounted all around. That's why I would like to know how to tell if it's a gearing problem with the speedometer or a VSS problem.
