Rough Idle Problem
Old Nov 27, 2006 | 12:03 PM
Socha_62's Avatar
Socha_62
Default RE: Rough Idle Problem
Take the TB off and clean it. Especially the IAC hole. The IAC itself gets gunked up alot but theres usually even more in the hole on the TB. Mind had all kinds of crap and gunk in there.
Old Nov 27, 2006 | 02:11 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: kstroeher
No paper gasket but there should be a rubber o-ring. My new one didn't come with one and but I re-used the old one.
The O-rings should always be replaced with a new one. When replacing the O-ring, it should be lightly coats with oil so as not to be torn during assembly.
Old Nov 28, 2006 | 09:12 PM
timwag2001's Avatar
timwag2001
ORIGINAL: Kev250R
Could be, I noticed today that the TB looked pretty dirty, I didn't remove it from the engine but I did spray some carb. cleaner in there while I had the IAC off.
--Kevin
not really too good to spray carb cleaner in tb while its still on the engine because all that crap falls into the intake manifold.
