97 Ram trouble code 15 speed sensor
Old Apr 20, 2007 | 04:12 PM
TMS Bill's Avatar
TMS Bill
Default RE: 97 Ram trouble code 15 speed sensor
Don't know how much this will help. Breakdown of OBD code 15. http://dodgeram.info/Engine-Gas/OBDI/Fault-15.htm
Old Apr 20, 2007 | 05:15 PM
sdouros's Avatar
sdouros
Thanks VWandDodge
I'll check all the grounds and wires.
Old Apr 20, 2007 | 06:01 PM
KevinFoshee's Avatar
KevinFoshee
"I checked the voltage going to the sensor and according to the Haynes Manual it should be 8 volts but I only got a reading of 5.4 volts. The signal voltage from the PCM gave the correct reading of 5 volts."
WOW! We really are having the exact same problem. My voltage readings are identical to yours!
I picked up a computer for $50 to see if my computer was the problem. The computer is from a 1998; so my tach doesn't work now, andI still have a Code for the vehicle speed sensor. I replaced the sensor, but it didn't help. Tried my 1997 computer again, but I still have the code.
I guess we're down to chasing shorts. I hate electrical problems.
Old Apr 22, 2007 | 01:25 AM
KevinFoshee
TMS Bill is right. We changed the wrong sensor. I found another sensor on the transmission that looked like the picture in TMS Bill's post. Once I replaced that sensor my Check Engine light went off (it took a few miles).
Since the book was wrong about which sensor was effected by a code 15; I'm assuming the voltages in the book are wrong as well. Since your readings were like mine, I'll assume everything is now correct.
Thanks TMS Bill!
Old Apr 22, 2007 | 01:48 AM
sdouros's Avatar
sdouros
Kevin
Where on the transmission is that sensor located at. I could only see the one on the side of the transmission?
Steve
Old Apr 23, 2007 | 11:46 AM
KevinFoshee
It is about 1 foot towards the front of the transmission and closer to the bottom.
Hope that makes sense.
Old Apr 23, 2007 | 04:04 PM
sdouros's Avatar
sdouros
Thanks KevinFoshee, TMS Bill and all others. I replaced the second speed sensor and now all seems to be OK. No more check engine light. I find it strange that the Haynes Manual did not mention this second sensor.
Steve
Old Apr 23, 2007 | 04:35 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: sdouros
Steve
Haynes is like the Cliff's Notes to the FSM. It covers the basics and gives a general idea, but overall isn't the best.
