Pinging and Knocking when "under load" >>
Old Nov 28, 2006 | 08:00 PM
ChrisTX's Avatar
ChrisTX
Default Pinging and Knocking when "under load" >>
I searched the 2nd gen forum and found tons of good info already on this subject.....but wanted to get some up to date clarification.
With normal driving, I do not hear any pinging/knocking. BUT...If I start to climb a hill at 55mph and the truck is still in OD I will hear what sounds like a pinging/knocking-maybe even a heat_shield_rattle type of noise. When it downshifts, I can still hear some knocking, but not as much as when it was in OD.
Oil consumption is about 1/2 quart every 5k. 202,000 miles, 5.9L, 4 x 2
What can I do to narrow the problem down? I understand it could be the plenum gasket, but could it be something simpler?
Has anyone here had similar symptoms? --and the fix, what did the real fix end up being?
Old Nov 28, 2006 | 08:03 PM
steve05ram360's Avatar
steve05ram360
Default RE: Pinging and Knocking when "under load" >>
sounds like the plenum... you should have a look at it.
Old Nov 28, 2006 | 09:15 PM
kayakman's Avatar
kayakman
Hi ChrisTX, I have a 98 quad cab 5.9L and have already had an intake manifold gasket installed. I have always had a spark knock in the truck since new and the only way it would go away is premium gasoline. Especially when I tow my 5th wheel.
I live in eastern Canada and even in the winter, it's premium gas.
Cheers KayakMan
Old Nov 28, 2006 | 11:51 PM
20dodgeram01's Avatar
20dodgeram01
get a 180 degree stat and run premium.. it'll go away
Old Nov 29, 2006 | 12:10 AM
mopar98's Avatar
mopar98
Turn the radio up!
[sm=happybounce.gif]
Old Nov 29, 2006 | 01:24 AM
Maintain's Avatar
Maintain
Try these three things...
1. Premium Fuel (for the pinging)
2. Use an oil additive ie: lucas (for the rattling)
3. When all else fails roll down the windows, turn up the heat with the radio
Old Nov 29, 2006 | 01:29 AM
timwag2001's Avatar
timwag2001
you could do the crank position mod if everything else fails.
instead of advancing the timing you'ld problably want to retard it.
Old Nov 29, 2006 | 02:39 AM
Ramdamit98's Avatar
Ramdamit98
-check plenum
-premium fuel
-colder heat range spark plugs like autolite #3923
-180* thermostat (but does reduce your interior heat)
-crank position sensor mod except retard timing (last resort)
Old Nov 29, 2006 | 02:40 AM
Socha_62's Avatar
Socha_62
Check the plenum, I'm with Steve
The 180 t stat will help though to, but not if the plenum is shot
