heater return hose "O" ring
Old Dec 1, 2006 | 05:25 PM
1RewdRam's Avatar
1RewdRam
Default heater return hose "O" ring
I recently did a bunch of stuff requiring removal of the return hose. After re-assembly I seem to have a coolant leak. When I re-assembled I just replaced the existing O-ring with a rubber one I had lying around. I seem to remember reading somewhere on here about using a Teflon ring instead of rubber. This true? Anyone know offhand what size it is so I can call around to find one? Thanks.
MOUNTAINEERS ARE ALWAYS FREE
Old Dec 1, 2006 | 08:08 PM
smartobject's Avatar
smartobject
Default RE: heater return hose "O" ring
If you mean that o-ring on that metal tube that comes off the Water Pump and points over toward the power steering pump --- I messed mine up by bending it. Even when I replaced a new O-Ring, it still leaked. So I got the whole part at the dealer -- $25.
Then I saw the same item at AutoZone (over at the "Help" brand stuff) for about $7. Sheesh....
Check it out,
Lee
Old Dec 1, 2006 | 08:16 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
I wasn't paying attention when I removed the old one. I put black RTV on the hard line when I put it into the pump. I didn't know I needed to use the O-Ring. Holds up tight.
Old Dec 15, 2006 | 11:29 AM
huttbutt's Avatar
huttbutt
I had same problem but it was not the o ring. The bracket on the metal tube that the bolt goes through must be mounted between the engine and the washer not the washer and the bolt. It must be perfectly square.
Old Dec 15, 2006 | 03:54 PM
1RewdRam's Avatar
1RewdRam
I got the whole tube thingy and just replaced it, problem solved, (that 0-ring, btw, was $3.10 from the dealer). Should have done it to begin with since it was somewhat corroded. In all I replaced the plenum, timing chain and gears, thermostat (180), hoses, water pump (lifetime guarantee!), flush/fill coolant, oil/filter change, truck plugs, wires, rotor, button, KN drop in, serpentine belt and tensioner. All this simply because a little straw popped off the throttle body spray and couldn't be found ( yes, the sum'bitch was in there alright). Think that's it, kept me busy. FYI: NEVER let yourself get bit by a Wheel Bug, Happened to me right before I started this project a coupla months ago, and I STILL have a nasty carbunkle on my back. DR says it can take up to a YEAR to heal.
Next: resurfacing/polishing headlight lenses, new headlamps/markers, and relay/wiring harness set up. Plus probably better bulbs all around. Still considering replacements for the driving lamps but Christmas is eating up my money and they are about $150 soooooooooo.
Old Dec 15, 2006 | 04:56 PM
k12allen's Avatar
k12allen
ORIGINAL: 1RewdRam
Wheelbugs can be nasty but it has a cousin even nastier that can leave an infection that's tough to cure and can killya.
Good thing is the infection is mostly in S. America - but sometimes it happens in Texas. SoCal too.
Old Dec 15, 2006 | 10:41 PM
1RewdRam's Avatar
1RewdRam
ORIGINAL: k12allen
ORIGINAL: 1RewdRam
............ and that cousin's name would be?
Old Dec 15, 2006 | 11:16 PM
Ram_Sport's Avatar
Ram_Sport
i, as well, would like to know the name of this cousin
