tranny quest.
Old Dec 2, 2006 | 06:23 AM
dirty_d's Avatar
dirty_d
Default tranny quest.
if i put my foot to the floor at hiway speeds the trans will shift down out of o/d rap up to about 3500 then rev real high like it tried to downshift again or its slipping. the trans has been beefed up only about 8 months ago. my father in law has an 01 ram as well only his is a 2500 but his does it as well. is this just a dodge thing?
Old Dec 2, 2006 | 12:33 PM
IndyRamMan's Avatar
IndyRamMan
Default RE: tranny quest.
mine does not do that; but what mine does, and I dont know if this is any help to you, is it will rev higher when I put overdrive back on when im crusin, and then it comes back down in about 2 seconds.
Old Dec 2, 2006 | 01:15 PM
mattyge's Avatar
mattyge
same here it will shift down 2 gears real high then upshift
Old Dec 2, 2006 | 09:46 PM
timwag2001's Avatar
timwag2001
put it in cruise control at about 70mph. does it still do the same thing?
Old Dec 2, 2006 | 11:50 PM
dirty_d's Avatar
dirty_d
only seems to do it if i put the pedal to the floor.
Old Dec 3, 2006 | 01:15 AM
Socha_62's Avatar
Socha_62
What gears are you running with those 37s? Could be working the engine to hard and its causing it to freak out.
Old Dec 3, 2006 | 05:10 AM
jisthangin01's Avatar
jisthangin01
Hey - I had my trans done, and when i got on it, it did that. It would shift, than shift again, but seem like it was slipping out of gear. However, one day i stayed on it, and noticed it wasn't slipping, just shifting up to the next gear revving to high. It was probably 500-800 rpms away from redline. I took it back, and they just had to make an adjustment. No big deal.
Old Feb 28, 2007 | 03:38 AM
dirty_d's Avatar
dirty_d
jisthangin01 did they say what adjustment needed to be made. when i talk to the trans shop they want to take it out and test drive it (costing about $50) to tell me whats wrong. the shop that built my trans is about 200 mi. away so i don't want to make that trip for a little adjustment. if i knew what adjustment needed to be made i could do it or tell them what it was. thanks
Old Feb 28, 2007 | 09:30 PM
TMS Bill's Avatar
TMS Bill
Off the top of my head, the only adjustment I can think of that will help is the TV cable adjustment.
Read these two threads:
https://dodgeforum.com/m_657994/tm.htm
https://dodgeforum.com/m_714068/tm.htm
Old Feb 28, 2007 | 11:36 PM
JarheadX's Avatar
JarheadX
mine does the same thing with that whole o/d thing. but im unclear on what you mean about it slippin, i hardly floor my truck anyway...not worth the loss of gas lol
