Exhaust "Y" pipe
Old Dec 4, 2006 | 04:54 AM
ripto's Avatar
ripto
Default RE: Exhaust "Y" pipe
ORIGINAL: nim81
you need an H pipe to connect the exhause together, otherwise its like running two 4 cylinder engines in your truck instead of one 8 cylinder. the H pipe or x pipe makes both sides of your engine run right instead if fighting eachother.
ORIGINAL: 20dodgeram01
you dont connect true dual at all.. from each header you run it straight back.
ooo which one is right?
Old Dec 4, 2006 | 10:30 AM
mntnceguy's Avatar
mntnceguy
Yes, you want an H or X pipe to balance the system, not a Y tho if ya want duals. X and H are essentially the same thing, just a way to connect the 2 sides of the exhaust, gives better power, and better sound. Maybe do a little research into exhaust systems so ya get a better idea of what ya want
Old Dec 4, 2006 | 09:42 PM
TMS Bill's Avatar
TMS Bill
ORIGINAL: ripto
ORIGINAL: Ram1500Dodge
h pipe is 2 cats(if desired/required) and 2 mufflers(if required/desired) boss. why would you have 2 cats and 1 muffler? H pipe just has a connecting pipe to balance out pressure.
so the H pipe is required or no?
AKA "crossover" ... it is not REQUIRED ... but it IS advantagous.
Read more: http://www.mustangforums.com/m_1028601/tm.htm
Old Dec 4, 2006 | 09:54 PM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: TMS Bill
ORIGINAL: ripto
like the mustang guys know what they are talking about. id sooner take true dual exhaust advice from a honda forum (if you dont get the humor, you shouldnt think of posting technical advice)
Not required...but you should call yourself dumb if you dont. Ballance the exhaust pressures. H pipe works well on pushrod small blocks that dont require ample "backpressure" (as it is so often refered to) X pipes seem to be good for OHC setups for some reason that I do not pretend to understand. I do know this, X pipes sound good on small smallblocks to reduce wrasp. ( I ran a double X setup on my lincoln (DOHC 4.6))
Old Dec 4, 2006 | 10:58 PM
TMS Bill's Avatar
TMS Bill
I have nothing against the Mustang folks ... except they don't drive a Dodge. But if I were to base my personal appreciations on that alone ... I'd be quite the hater. That's just not me.
Come on, now ... they guy's name is "Professor Wizard" ... think about it ... he's a professor ... AND a wizard! How can you possibly go wrong?
Old Dec 5, 2006 | 10:58 AM
mactools124's Avatar
mactools124
either one will work the X or H pipe. Because you should balance out the two banks of cylinders that way they don't fight each other with back pressure.
1997 1500 ram 4x4
5.9L v8 magnum
flowmaster 40 seris daul rear exit
k/n air filter (coming soon)
Old Dec 19, 2006 | 01:33 PM
Dodge4x4magnum's Avatar
Dodge4x4magnum
yeah well me and my frined are putting it on and since the left side header comes over to the right side, then they go back, both connect into the cat then come out at 1 pipe. then after that they split into two. I just needed the other y pipe to cut up to curve it back and i am going to use an H pipe with two SLP mufflers
