waterpump
Old Dec 6, 2006 | 02:29 PM
muddy_blue_dodge's Avatar
muddy_blue_dodge
Default waterpump
am i correct that consistently running a little over 200* (runnin 210*ish) might be a waterpump problem? if so, how hard are they to replace?
Old Dec 6, 2006 | 03:09 PM
bamory's Avatar
bamory
Default RE: waterpump
Any leakage around the shaft/seals? Any strange noises? What type of thermostat (use 180*)? Whens the last time you flushed the system? What did you fill it with? How is temp in your area? When the last time you changed oil? Any pinging d/t heat?
I wouldnt change it unless you know thats your problem. I would flush, refill using 50/50 with distilled water. Old oil will allow motor to heat up also. When you do the flush make sure you flush heater core also.
Also not hard to replace just gotta get everything outta your way.
Old Dec 6, 2006 | 06:46 PM
muddy_blue_dodge
no leakage; no strange noises... i dont think; stock t-stat (195*); most recent flush was by PO about 2 years ago; temperature ranges from 40-80 over past 60 days (its been goin a while); and oil changed regurally.
so is there a way to make sure its my waterpump before i replace it?
Old Dec 6, 2006 | 08:29 PM
Socha_62's Avatar
Socha_62
The only really way the water pump can go bad is for the pulley to fly off causing lots of bad things. When that happens the little holes start leak to signaling its going bad.
My bet is on the coolant and t stat. Swat them both out this weekend. Will be way cheaper then a water pump!
Old Dec 6, 2006 | 10:47 PM
mattyge's Avatar
mattyge
yeah when the water pump is going you'll hear the bearing squeal
Old Dec 7, 2006 | 01:40 AM
muddy_blue_dodge
appreciate it guys. it wouldnt hurt the truck if it had to wait, o, say, 3 weeks would it? i have exams between now and christmas break, i think ill have to do it then. i appreciate the help
Old Dec 7, 2006 | 02:12 AM
Ram_Sport's Avatar
Ram_Sport
my waterpump took a crap, it started leakin on an internal seal on the pump itself and i noticed lower amt. of fluid and we had to have it replaced they also did a new tstat.
