Hypertech or Mopar PCM
Old Dec 7, 2006 | 12:53 AM
kikidbird's Avatar
kikidbird
Default Hypertech or Mopar PCM
What is better, Hypertech or Mopar PCM. I have a 1999 Dodge Ram 1500 4x4 318. The engine is Hot Doged, K&B Pistons .030+, Crane Cam Extreme, Edelbrock Performance Heads, 1.7 roller rockers, 166K 2250-2350 stall torque converter, MSD 6A ignition and coil, K&N cold air intake, headers, catback exhaust( -catcnvtr), 33" tires. Can I use Both Hypertech and the PCM?
[IMG]local://upfiles/33441/C37A2D1574DA48A89CBBF16263DEF3A2.jpg[/IMG]
Old Dec 7, 2006 | 02:06 AM
Ram_Sport's Avatar
Ram_Sport
Default RE: Hypertech or Mopar PCM
should get a custom tune from like bg or whoever does the tunes maybe krc idk, look into custom tunes w/ ur setup tho fo sho
Old Dec 7, 2006 | 02:27 AM
Silver_Dodge's Avatar
Silver_Dodge
Having used both, the Mopar PCM is better then the programmer hands down, and it would give you much better results with the mods you have. The Hypertech programmer is designed for stock and near stock vehicles. With your mods though, you should definetly contact B&G for a custom flash. You would see the best results from that i'm sure.
No, you do not want to use the Hypertech with a Mopar PCM because you would essentially just be using the Hypertech since it replaces the PCM's programming with its own.
Old Dec 7, 2006 | 02:52 AM
kikidbird's Avatar
kikidbird
What is a B&G flash?
Old Dec 7, 2006 | 03:05 AM
Ram_Sport's Avatar
Ram_Sport
A B&G flash is actually a company who reprograms your eprom with custom tuning to your specs and should be perfect for your application idk how expensive it is, but i know it prly will cost a bit.
http://www.bgperformancepcm.com/
Old Dec 7, 2006 | 01:25 PM
Silver_Dodge
Its between $300-$600 depending on what you get. Go through the Fastman to get it though, he gets a discount.
Old Dec 7, 2006 | 11:41 PM
hawkeyedodge's Avatar
hawkeyedodge
Ive got a hypertech and I love it, but I wish I could get a Mopar Performance PCM for my 01
Old Dec 8, 2006 | 01:10 AM
kikidbird's Avatar
kikidbird
Im going to run my Stage two power chip, then ill buy the Hypertech and check it out.
Old Dec 8, 2006 | 03:11 AM
Silver_Dodge
Jet chips are worthless. You will feel a gain at first, but since the stock PCM settings are still present, it will compensate to bring everything back into spec per its preprogrmmed settings. That is why programmers, performance PCM's, or custom flashes are the best way to go. They all replace the stock programming so the PCM has no choice but to use the new values.
Old Dec 8, 2006 | 01:38 PM
Tani1500's Avatar
Tani1500
X2 totally agree and you should definalty get the flash with your setup !
